Simon Phillips avatar image
Simon Phillips asked
Old Multiplus 12/3000/120 with smart BMS CL 100/12 will it work ?
Having had enough of running my generator for hours and hours in the winter to get my AGM's to 100% charge ( summer no problem with my solar ) I have decided that as soon as I can afford it I am switching to 2 x lovely new 200Ah Victron Smart Lithium's .
I plan to use Smart BMS CL 100/12 as my BMS in order to integrate by alternator and also my Midnite solar controller .
The Midnite can be configured to accept the Charge disconnect output of the BMS but I have an old 2007/08 Phoenix Multiplus 12/3000/120 and not sure if I can shut down the charger and loads on this with the BMS , It does not have Aux inputs of the later models .
I don't really want to spend on a new one especially since my outlay on new batteries is large and the ole Victron is in really good condition and working fine so why bin it ? there must be a way of shutting it down ? can the Cyrix Li-Charge / Load be used for example and if so how ?
Many thanks in advance
imon
MultiPlus Quattro Inverter ChargerLithium BatteryBMS
