Is a 3 phase system with 3 phase AC input and single phase AC Input possible?
I have a 3 phase system with 3 Multiplus II and i want add additionally a single Phase Mulitplus to load the Battery.
The Battery is a BYD LVL 15.4 kw with BYD BMS
You can use the current MP to do that. Configure 1-phase generator to L1 and adjust settings that In the case of phase two and three failure, the Master will continue charging the battery.
Hi, according to the VE.Bus system configurator turtorial, this should be possible:
I have never tried that by myself, but it would not be in the turtorial if it would not work ;o)
BR
Markus
22 People are following this question.
