Good day Victron Team.
I would like to know how can I set up a system so that I can use the batteries when utility tariffs are high. When low tarrifs the system must then bypass.
Is there a way to do this?
Regards
Hi Gerrie
I am going to assume that you have a CCGX or Venus GX?
If you access the menus Settings -> ESS -> Scheduled Charging, then you can set times when you want to use grid power or not.
https://www.victronenergy.com/live/ess:design-installation-manual#venus-device_-_scheduled_charging
Yes I do have a ccgx. Thank you for the answer.
Much appreciated
5 People are following this question.
