I can't connect to victronenergy.com today and also verified on https://www.isitdownrightnow.com/victronenergy.com.html that it can't access the site either.
Verified by checking the DNS table and community.victronenergy.com and victronenergy.com go to two completely different IPs
It started working within the past 3 hours. There were other sites having issues as well that also started working. So do think it was a more widespread issue like a CDN having problems. Thanks for checking.
Hi @dbainbridge,
The Victron networks use a CDN, so depending on where you are, you will see different servers (hopefully the fastest one for you).
The main domain is working for me - I am served this IP - http://46.19.36.124
and the site checker I like says it's up too - https://downforeveryoneorjustme.com/victronenergy.com
But that doesn't mean there isn't an issue. I will wait to see if anyone else is reporting problems before escalating.
For reference when I tried multiple site checkers from the USA they were saying victronenergy.com was returning a 404. But has started working again along with other sites that I also saw having issues so likely was CDN..
Currently it is online and I also had no problems the whole day.
26 People are following this question.
