jc1 avatar image
MPPT Control conection - only says "Connecting"
I've just installed a Smart Solar MPPT 150/45 and a MPPT control. The MPPT control only displays "connecting". Pressing the buttons doesn't do anything. They are connected with a VE direct cable. Is there something else that has to be done to get the display control to work?
MPPT - Solar Charge Controller
Paul B avatar image
Paul B answered ·
Make sure your phone that you are trying to conect is also ON THE Internet as the unit may need a firmware update
Hi @jc1, what you are seeing is an issue with the MPPT Control.
It needs a firmware update to work properly with that Solar Charger. The required firmware version is v1.01.
Its unfortunately not field updatable; please contact your dealer to have it replaced under warranty.
I noticed just now that we don't have information available about this in Victron Professional (ie. a change log, with all the details); I'll make sure that that change log is made and put online within a few days.
kryz avatar image
kryz answered ·
I just read the above and checked my MPPT Controler and its V1.0.
Do I also need to get this a firmware update ???
Im now living in another country from where I bought it and no longer have the receipt. Is a firmware update still possible?
Thank you
Hi, please contact a dealer or distributor. It will be replaced under warranty without any hassle.
Firmware updating is unfortunately not so easy that we allow it in the field.
trevor-bird avatar image
trevor-bird answered ·
I had swapped out the MPPT control three times on our yacht for this fault. When first swapped the MPPT control would work well for week or two and then simply scroll ”CONNECTING”. The problem became frustratingly repeatable. I gave up after being asked by the dealer to swap out the VE.Direct cable. We have stopped cruising for a while so today I swapped it’s gain for another new one. It is still firmware version V1.0. It is working again but I have little faith it will continue to do so. It seems like a software issue like a buffer filling or stack overflow as after a short time it fails and simply scrolls “CONNECTING” on the screen. I will see how it goes this time (4th swapout).
Hi Trevor, we recently found a few issues with the MPPT Control; and are working to fix it - either with a MPPT Control firmware update and/or MPPT firmware update. I expect to have more news within a few weeks.
My apologies for inconvenience caused and thank you for your patience. Four swap-outs is of course totally unacceptable.
trevor-bird avatar image trevor-bird mvader (Victron Energy) ♦♦ ·
Hello mvader and thanks so much for the response. It was a very interesting fault as the new unit would work for a while and then go back to the fault condition. Great to hear the problem is well known to Victron and is resolved.
Hi all, good news; the issues are fixed now with new firmware versions: both for the mppt control and for the solar charger.
VictronConnect version v5.34, released yesterday, contains both those new firmware versions:
- update victronconnect (if it doesn’t do so by itself)
- connect to the solar charger, and update it (go to settings, product information)
- connect to the mppt control (see its change log on https://professional.victronenergy.com for how to do that; it requires the special mppt control power cable), and then the update will start automatically once you connect.
more details on how to connect are in the VictronConnect manual.
My apologies for the trouble, and also that it took us so long to fix.
All the best, Matthijs
Nice that you take care of this issue. Unfortunately for me the updates do not fix the problem.
walmsleyc avatar image
walmsleyc answered ·
I have a Smart Solar 75/15 connected to a MPPT Control. It's be installed for 2+ years, and working well. Now, twice in the last month, the MPPT Control unit just says "CONNECTING" and buttons do nothing. Disconnecting the ve.direct cable and reconnecting gets it going again.
Firmware versions:
  • Smart Solar 75/15: 1.56
  • MPPT Control: 1.0.1
Is there anything to do? does the MPPT Control unit need a firmware update?
arm-d avatar image
arm-d answered ·
I have the "CONNECTING" connecting issue with my Smart Solar 75/15. I have the system running since 2019 and the the problem appeared in MAY 2021, so I think it came from an update of the Smart Solar. I did regular updates and the Smart Solar has the firmware rev 1.56.
My MPPT Control unit was updated in JULY 2021 to rev. 1.02 and the problem was gone for some days, but now the "CONNECTING" issue is back again, so the firmware update did not fix the root cause.
This is very disappointing and I have already put a lot of effort in frequent resetting the system and finally uninstalling the control unit to update it without any success.
There is not even a simple method to do a reset, so every time the connection is lost I have to unplug the unit, which is not an easy task.
Hi @ARM_D , that sounds rather bad indeed! My apologies for all the troubles. MPPT firmware v1.02 is the latest one available, and we're not aware of any issues with that. I've asked a colleague to contact you and get this working as it should.
Hi @ARM_D
I've sent you an email to resolve this.
joelscarr avatar image
joelscarr answered ·
I have the same issues as noted here and on another thread. We have the MPPT 100/20 with the MPPT control. The first control ordered earlier this year showed "connecting" after a week or so of being installed and was replaced under warranty. The replacement did the same. Now the third unit, which the supplier said they updated before shipping it to me, now also simply says "connecting" after a week or so of being installed. I would be very grateful if Victron could please advise a final solution.
Thank you
