stuffen1 avatar image
stuffen1 asked
Inverter AC outlet not working using dual output PS brick
I have an 375VA inverter that exhibits no AC when connected to a dual output DC PS brick but it works with a single output DC PS brick. (tried it with 800VA inverter and got the same results) I'm using a blue tooth dongle to monitor the AC output and confirms there is a problem. I assume I may have a PS switching noise feeding back to the inverter. I installed an EMI filter between the inverter and the dual DC PS brick. Still no AC.
Any advice?
Phoenix Inverter
Justin Cook avatar image
Justin Cook answered ·
Hi @stuffen1, welcome to the Community!
This is not a supported connection method at all, so I'm afraid that you're unlikely to find an answer here. Whenever connecting components in a manner other than as specified in the manual, it must be a recognized danger that those components may not perform as expected.
