johng avatar image
johng asked
Is there any documentation of the parameters provided in the csv download from the Advance dashboard related to my system?
I have downloaded the csv reports from my neighbours system via the Vitron portal. I have searched for documentation on each of the fields but not found anything and hoping that someone could help.
For example looking at VE.Bus System [0] and Input phase 1 I would expect Power to be equal to Current multiplied by Voltage. The latter VI calculation fluctuated wildly where Power is relatively well behaved. I suspect that the Current is simply an instantaneous value where Power is averaged.
I am working on evaluating different Tariffs from our local municipality who have now introduced Time of Use (TOU) Tariffs on top of the normal energy tariffs. The municipality is encouraging the TOU tariffs which better reflect their costs.
A possible Win-Win for User and municipality.
Thanks, John
VRM
Given your use case of analysing energy consumption at different times of day, have you tried working with the kWh download?
I think it will be more useful to you.
johng avatar image johng commented ·
Hi Guy,
Thanks for the quick answer. I think you are 100% correct. I was not sure what the difference was between the different csv files.
I have a slight logistical problem as the download link goes to my neighbours email and he does not always notice in time to download and forward. That is why I only got the one report so far.
So you've answered the immediate question, but is there any documentation for the download fields?
There is not extensive or specific documentation for the advanced download, as far as I know.
Regarding Current, Voltage and Power, for AC, the relationship is not as easy as P = IV. There is another component called power factor which introduces reactive power, as compared to real power.
There is more information in Chapter 6 - AC Wiring in Margreet's Wiring Unlimited - https://www.victronenergy.com/upload/documents/Wiring-Unlimited-EN.pdf
Are there any others you would you like further info on?
timestamp
Gateway VRM Log time offset
Gateway ESS Scheduled Charging
Gateway Relay 1 state
Gateway Generator run reason
Gateway CCGX Relay 2 state
VE.Bus System Phase rotation
VE.Bus System Input voltage phase 1
VE.Bus System Input current phase 1
VE.Bus System Input frequency 1
VE.Bus System Input power 1
VE.Bus System Output voltage phase 1
VE.Bus System Output current phase 1
VE.Bus System Output frequency
VE.Bus System Output power 1
VE.Bus System Voltage
VE.Bus System Current
VE.Bus System Battery temperature
VE.Bus System Active input
VE.Bus System Active input current limit
VE.Bus System VE.Bus state
VE.Bus System VE.Bus Error
VE.Bus System Switch Position
VE.Bus System Temperature
VE.Bus System Low battery
VE.Bus System Overload
VE.Bus System Temperatur sensor alarm
VE.Bus System Voltage sensor alarm
VE.Bus System High DC Ripple
VE.Bus System Temperature L1
VE.Bus System Low battery L1
VE.Bus System Overload L1
VE.Bus System High DC Ripple L1
VE.Bus System Temperature L2
VE.Bus System Low battery L2
VE.Bus System Overload L2
VE.Bus System High DC Ripple L2
VE.Bus System Temperature L3
VE.Bus System Low battery L3
VE.Bus System Overload L3
VE.Bus System High DC Ripple L3
VE.Bus System Charge state
Battery Monitor Voltage
Battery Monitor Current
Battery Monitor Battery temperature
Battery Monitor State of charge
Battery Monitor State of health
Battery Monitor CVL - Charge Voltage Limit
Battery Monitor DVL - Discharge Voltage Limit
Battery Monitor CCL - Charge Current Limit
Battery Monitor DCL - Discharge Current Limit
Battery Monitor Discharged Energy
Battery Monitor System; minimum cell voltage
Battery Monitor System; maximum cell voltage
Solar Charger Voltage
Solar Charger Current
Solar Charger Battery watts
Solar Charger Battery temperature
Solar Charger Charger on/off
Solar Charger Charge state
Solar Charger PV power
Solar Charger Relay on the charger
Solar Charger Low batt. voltage alarm
Solar Charger High batt. voltage alarm
Solar Charger Yield today
Solar Charger Maximum charge power today
Solar Charger Yield yesterday
Solar Charger Maximum charge power yesterday
Solar Charger Error code
Solar Charger User yield
Solar Charger PV voltage
Solar Charger PV current
Tank [20]Tank status
System overview AC-Input
System overview PV - AC-coupled on input L1
System overview PV - DC-coupled
System overview AC Consumption L1
System overview Grid L1
System overview Voltage
System overview #1 Low SOC; discharge disabled
System overview #2 BatteryLife is active
System overview #3 Charge disabled by BMS
System overview #4 Discharge disabled by BMS
System overview #5 Slow charge is active
System overview #6 Charge disabled by user setting
System overview #7 Discharge disabled by user setting
System overview Current
System overview VE.Bus charge current
System overview Battery Power
System overview VE.Bus charge power
System overview Battery State of Charge
System overview Battery state
System overview DVCC Multiple batteries alarm
System overview DVCC Firmware insufficient alarm
System overview Grid alarm
PV Inverter L1 Voltage
PV Inverter L1 Current
PV Inverter L1 Power
PV Inverter L1 Energy
PV Inverter Error
Grid meter Grid L1 - Power
Generator start/stop Generator not detected at AC-input
Temperature sensor Temperature
Temperature sensor Temperature status
zain avatar image zain commented ·
Could you tell me about
johng avatar image
johng answered ·
Thanks again Guy,
I have now managed to get the kWh download.
Time steps are every 15 minutes, I presume the kWh are for the previous 15 minutes.. Can anyone confirm?
I would also like to know how to work out total kWh to Grid and kWh from Grid as they are metered at different rates.
My assumption is:
kWh to Grid = PV to grid + Battery to grid
kWh from Grid = Grid to battery + Grid to consumers
Can anyone confirm?
Thanks again,
The list of headers are as follows:
timestamp (TimeZone details)
Solar Yield (delta) (kWh)
Grid to battery (kWh)
Grid to consumers (kWh)
PV to battery (kWh)
PV to grid (kWh)
PV to consumers (kWh)
Battery to consumers (kWh)
Battery to grid (kWh)
Genset to consumers (kWh)
Genset to battery (kWh)
Gas (m3)
johng avatar image
johng answered ·
I did some checking against the portal and the kWh are actually for the subsequent 15v minutes as shown under period above.
We'll get this documented by hook or crook :-)
