bite avatar image
bite asked
Is it possible the Quattro to always function as a double conversion?
In a situation where the load is very critical and to ensure that we have a perfect wave at the output of the quattro, I would like to know if it is possible to configure the quattro as a double-conversion equipment.
In other words, the charger and the inverter are always working and the equipment does not make transfer switch.
I think, quattro does not allow this kind of configuration, but if it is possible or there is another solution to get around the problem thank you in advance for your suggestions.
chargerPhoenix Inverter
wkirby avatar image
wkirby answered ·
No there is only one converter inside. It is not possible to charge and invert at the same time.
To do this you need to have an external charger like Skylla or another Quattro which is only doing charging (switch to charger only).
ostrovni-elektrarny avatar image
ostrovni-elektrarny answered ·
We have tried to do so too, for factory full of robots. Not possible with actual Victron inverters. We are using Voltronic Axpert King inverter for this purpose instead.
