knibbsy avatar image
knibbsy asked
No current draw readings from BMV-702
I have done a re-install on a previous 12 volt setup in my Landcruiser. Prior to removing this setup the BMV-702 was functioning correctly.
Now after a re-install, the BMV-702 is working and connecting via the app to my phone but it is not reading any current draw when load is applied to the auxilary battery.
I have re-installed using the factory wiring diagram and checked it over, so it should be correctly wired.
If I turn the ignition on the app with begin reading current draw, but in large amounts.
I have reset factory settings, re-installed and updated the app with the latest firmware.
Can anyone please help.
input current
