jonmarinello avatar image
jonmarinello asked
75/15 Solar Controller jumper and connecting Cerbo GX
I want to connect my 75/15 Solar Controller to my new Cerbo GX. There is a jumper in the communication port. I plan to remove the jumper so I can connect the Cerbo GX with a cable. Will doing this cause any problems? What will change with the 'batterylife" behavior if anything?
MPPT Controllerscerbo gxVE.Direct
wkirby avatar image
wkirby answered ·
The position of the jumper selects two different load disconnect options.
No jumper means batterylife is selected.
You can remove the jumper and connect the cable between the MPPT and CerboGX.
jonmarinello avatar image jonmarinello commented ·
Thanks for the prompt reply.
