SoC Charger MPPT Blue Solar
Presuming that you also have a bmv-7?? installed and connected
In the CCGX unit under settings change the relay to Generator start/stop
then under settings select the generator start/stop option and under conditions using SOC you can control the CCGX relay state, then use this relay to turn the Solar Charger off at 80% and back on at 40%,
14 People are following this question.
