Gabriel Tanasescu avatar image
Gabriel Tanasescu asked
in ESS system the Pv Fronius Inv. feed in the power no charging the battery ..
Hi All .
I get a problem with a below system three phase Victron + Fronius running in ESS .
The power from Inverters don't charging the baterii , the power go to feed in to Grid ...this Ess working right. the Et340 need to be update ?
I try al the configuration from Ess ,but no succes .
Please help to me with a right asasinat settings for this configuration...
ESSEnergy MeterAC PV Coupling
Gabriel Tanasescu answered ·
The problem is solved ..I removed the communication from Tesla BMS to Gx Control
Meine_Energiewende avatar image Meine_Energiewende commented ·
Which BMS do you use ? Normally the BMS tells the GX (and other devices) what to do ?
Jens
Gabriel Tanasescu avatar image Gabriel Tanasescu Meine_Energiewende commented ·
It is the third party BMS
