tim22 avatar image
tim22 asked
Smart BMS CL 12/100 - connections and compatibility?
I would like to connect my alternator and smart solar mppt controller to the start battery and then to the alternator/start terminal on the BMS CL 12/100. This is on a 30 ft sailboat and I don’t run the engine enough to ensure that the start battery is kept charged so this configuration would ensure that the solar charges the start battery before the house bank.
i would also like to know if the BMS CL 12/100 would work in the above scenario with non Victron LiFePO4 batteries (i.e. battle born or re-lion)
Thanks
Tim
BMS
The Victron BMS is only designed to work with Victron smart lithium batteries.
diamach avatar image
diamach answered ·
@tim22 Hi Tim, i'm wondering the same, i have that setup too, did you have any luck trying it?
Woody avatar image
Woody answered ·
Has nobody had experience with this enough to answer this question? The Victron website only mentions Victron batteries which really makes me wonder.
