billk avatar image
billk asked
Has anyone used a Duromax XP12000EH with Quattro 5kW in parallel?
Manual says to check with dealer about suitability of generator brands for use as backup for those inverters, thought I'd check in with the Community. The Duromax looks like a pretty good unit but thought I'd see if anyone has used one and if so what results you've had.
By the way, Champion Power Equipment specifically states that if you use their generators to back up your solar system in an off grid configuration your warranty is null and void.
MultiPlus Quattro Inverter ChargerGenerator
