Matthias Lange - DE asked
BMS 12/200 and MultiPlus 12/3000
is it possible to connect a MultiPlus 12/3000 to a BMS 12/200?
The datasheet says it should be possible because the BMS will limit the inrush current to 80A for a while and will than switch back to 400A max.
But I know we had a few problems with larger inverters at the BMS 12/200 a few years ago.
The BMS got killed in the moment you connected the inverter due to the high inrush current.
Back then the BMS 12/200 was just released.
Today I got a call from a costumer, he want to upgrade his RV installation.
He already have a Victron Smart LiFePO4, a BMS 12/200 installed and a no-name "3000VA" inverter.
Now he want a MultiPlus 12/3000 but because we made some bad experiences I don't want to sell and install the Multi without being sure it will work and not kill the BMS.
Greetings from Germany
MultiPlus Quattro Inverter ChargerLithium BatteryBMS
Neo Nos avatar image Neo Nos commented ·
While I got you online lol, (you just answered one of my questions and I found you were the questioner of my next question) What did you end up doing with this? I also have a Multiplus 2 3000 and based on the answer here I am thinking not use the system+... however the 200AMP rating of 12-200BMS seems enough as I thought Multiplus was only 45amps.
Margreet Leeftink (Victron Energy Staff) avatar image
Margreet Leeftink (Victron Energy Staff) answered ·
No it is not possible to run a MultiPlus 12/3000 from a BMS12/200. The startup current is too high, and if the MultiPlus is running at full power it exceeds the 200A rating of the BMS. And don't forget that a MultiPlus has a 6000W peak rating (this is 500A @12V).
I would recommend to use a Smart BMS CL 12/100.
I thought the only difference between 12/100 and 12/200 is the negative vs positive side. Or I read so in this forum. What difference does that make?
Looking into this? It seems BMS 12-200 has everything 12-100 has to why are you recommending this? To save money since the built in battery protect is not being used?
