andi avatar image
MPPT 75/10 and blue smart charger in parallel?
Hey, i'm currently working on a small mobile solar station with a Victron Li-Ion-Battery for education purposes. When the station is outside it should yield its energy via an solar panel and the Victron MPPT charge controller. When not in use, it will probably stay inside for a longer time. For this case it would be great if the battery coulld be charged via the Victron Blue Smart charger off the grid. Is it possible to connect both devices, the Blue Smart Charger and the MPPT solar charger, in parallel to the Li-Ion battery? (VE.Bus BMS will be installed)
To my understanding, since both devices work in the same output voltage range, this shouldn't be a problem.
Many thanks in advance
Andi
MPPT - Solar Charge Controllerinstallationparallel
Alexandra avatar image
Alexandra answered ·
@Andi
It is totally possible to use both to charge at the same time. I have a 75/15 and use the the blue smart at the same time. Not using the victron battery bit an enertec li-ion.
hardstuff avatar image
hardstuff answered ·
Can the charger be more than 10 amps ?
If you have a 75/ 10 than it can only charge with 10A.
If you need more charge current you need to use a bigger MPPT.
Charging is limited to the rate the battery can accept, so your grid charger can be higher than 10A if the battery will accept that.
