toby avatar image
toby asked
Can I use a 24/3K Multiplus control board in a 24/3K Phoenix inverter
Control board is faulty in an old Phoenix Inverter, to confirm I have replaced the board with a Multiplus control board of the same rating. The Phoenix Inverter is now working under load. The LEDs are flashing on the control board as expected as there is no charging function on the Phoenix Inverter.
The out of warranty unit is now working and whilst not ideal, is there a problem with this set up long term?
Thanks
Phoenix Inverter
