I want to install a 48V LiFePO4 Battery system with an EMUS BMS, if I connect the EMUS BMS to the CCGX do I still need a BMV in order the monitor my battery on the CCGX?
Thanks in advance
Thanks in advance
Hello Kai,
maybe the answer is too late for you, but you can connect the EMUS BMS via Can-Bus to the VE.Can or Can.BMS connector of a GX device. I‘ve dine this with a Cerbo GX.
Peter
Trying to get this to work right now. What were your EMUS can settings to get it to talk to the Cerbo GX?
Have it set to 500kbps on EMUS and Cerbo on the BMS-Can port but so far not seeing anything.
27 People are following this question.
