Has anyone connected a MASE Marine IS 5.0 generator for automatic Start and Stop with Raspberry Pi with Venus OS? Can you tell me connection diagram, thanks
Hi the Venus unit has a on/off relay, only
you have to make up a interface box that trigers a start on the Mase when the relay close's and a stop when it opens,
I use some timers that hold the start button down for 5 sec when it close's and then a stop timer when it opens
No need for Raspberry Pi unless you are doing something very complex.
If you implement this it should work.
https://www.victronenergy.com/live/auto-generator-start-stop:start
Regards,
Trevor
29 People are following this question.
