grunkern avatar image
grunkern asked
NO Consumption Data
Dear Tech Folk and @nebulight
I have a Solar Panel wired to an MPPT 100/30 NOT Bluetooth
MPPT 100/30 wired by USB to Raspberry Pi 3 with Venus
Also Smart Battery Monitor BMV-712 which is wired via Shunt to negative of battery one side and negative of appliances on the other site
BMV-712 Also wired to Raspberry Pi via USB cable
All USB Cables are Victron Made
Data is transmitted to VRM Portal
Devices show up in Venus OS
The battery is single 160AH deep cycle AGM Gel
This set-up is in a Small Motorhome with 285W Solar on Roof
I get no readings of consumption through the Raspberry Pi on the VRM Portal
Any ideas welcomed
Thanks in Advance
Robert
Venus OSRaspberry Pimonitoring
JohnC avatar image
JohnC answered ·
Hi Robert.
Try enabling 'Has DC system' in 'System setup' of the Venus screen. Only then will it calculate the dc output, so it may take some time to gather enough data to show a useful period on VRM.
On VRM, look in 'System Overview' for the relevant widgets.
If you've already done this, please say..
grunkern answered ·
THANKS @JohnC, that has sorted it out
JohnC avatar image JohnC ♦ commented ·
Ooh, apologies.. I really meant look in 'Advanced' > click on Widgets (top rhs) > System Overview > select Widgets.
But you likely did that anyway if you know your way around VRM.
Good you've sorted it either way, and I wish you well in your travels.
