Hi, since I've replaced batteries on my Victron BMV - 602S the display show the error you can se on the picture below. Any press of buttons doesn't work. What does it means?
thank you.
thank you.
Hi Anxur,
This message means that the BMV is in firmware update mode. You could try to disconnect it for a short while an reconnect again. If this does not help, the unit might be defective.
Regards,
Thiemo van Engelen
23 People are following this question.
