peterbr avatar image
peterbr asked
TR Smart 24/12 isolated charger settings
Hi have a lithium battery and i would like to know the settings in the Bluetooth connect app i should use to charge it. The charger is in my truck which is 24v, i use the 12v battery to run my head unit, uhf radio, GPS etc etc Thank you
Battery Specifications:
* Nominal Voltage: 12.8V
* Nominal Capacity: 100Ah
* Usable Capacity: 100Ah
* Energy: 1280Wh
* Charge Voltage: 14.6V
* Discharge cut-off voltage: 10V
* Charge Method: CC/CV
* Charger: 14.6V20A
* Standard Charge Current: 20A
* Max. Charge Current: 50A
* Standard Discharge Current: 50A
* Max. Continues Discharge current: 50A
* Max. Discharge Current: 5Seconds125A
* Cycle Life: 2000 times
* Internal Impedance: <=50mΩ
* Discharge: -20°C-60°C
* Storage Temperature: -10°C-50°C
* Working Temperature Range Charge: 0°C-45°C
VictronConnect
