albert-vd-westhuizen avatar image
albert-vd-westhuizen asked
Requirement for delayed battery charging from mains after grid return
I have a requirement for the system to not charge the battery from grid for a set period of time, say 30 minutes, after grid has returned following a power outage/loss of mains.
Ignoring AC in for same set period after grid return would also be a solution but secondary to having only battery charging delayed as loads on inverter output would also be affected. Would be ideal if this can be achieved using some combination of Assistants and programmable relays.
battery chargingGeneratorAssistants
VEConfigure Assistants manual
MultiPlus Generator FAQ
GX - Generator auto start/stop
Automatic Generator start/stop
 Hybrid Generators
Virtual switch - Generator start/stop
