Is tank volume calibration possible using Venus GX inputs like the "VE.Net Tank Monitor"?
Hi, the shape of the tank is not calibratable; if thats what you mean. Size / volume is configurable; yes.
Hi, Thank you for your answer. I mean if it is possible to calibrate the output of a tank sensor to certain volume in the Venus GX because of an unusual tank shape (like the calibration process using the "VE.Net Tank Monitor" and CCGX or similar).
Additional question, is it possible for the Venus GX to calculate and show the volume according to the input value of the tank sensor and a custom function provided?
3 People are following this question.
