frank-ster avatar image
frank-ster asked
Multiplus II 48 volt. Low battery alarm vs turn off inverter voltage
So I am running a 20 kWh lithium pack , I set my low voltage turn off for the inverter . But the alarm minimum setting is minimum 4 volts higher . The problem I am having is if I turn off my inverter when I’m not using it I can’t turn it back on untill it’s above the low voltage alarm . Which in my case is an enormous amount of energy .
How can work around to set the low voltage alarm with in 1 or 2 volts above the inverter turn off voltage ?
Multiplus-IILithium Battery
frank-ster answered ·
V459.
Says it’s the current version.
ok, so you have to update the firmware.
The change you need came with version 464.
Changed minimum difference between DC input low shut-down and
DC input low restart voltages from 1V/2V/4V to 0.25V/0.5V/1V (12/24/48V systems).
This allows systems to use a lower DC input low restart without the need to use a
lower DC input low shut-down then also.
(n.b. Lowest allowable DC input low restart is 10.9, 20.6, 41.2V (12/24/48V systems))
The update you can get via the Victron professional portal or via VictronConnect.
Save your settings!
What firmware version is running on the Multi (Target -> Show software verson)?
If I remember correctly there was a FW update a while ago that changes that.
Battery Compatibility
