anton859 avatar image
anton859 asked
Battery Capacity for Multiplus 5000
Hello, I had a question: can I use the Multiplus 5000 24 v with a 300 Ah battery? The manual indicates the recommended capacity of 400-1400 ah, what does it threaten and did anyone come across this situation? Battery connected via lunx ion BMS and DVCC enabled.
MultiPlus Quattro Inverter Chargerbatterybattery capacity
What kind of batteries do you have?
This Multi has a peak power of 10.000W so your battery must be able to deliver over 400A @ 24V.
anton859 avatar image anton859 commented ·
One mghe 240300 24v / 300 ah battery, rated power 7.5 kWh, as I understand it, if the inventory does not work at full capacity, is this not critical?
