In 24v system, with 4 lithium batteries does the order of the battery interconnection with M8 circular connector matter?
Thank you!
Thank you!
Hi
Question :
4 *??? Volts batteries ?
4 x 6V in serial ?
4 x 12V (2S-2P)?
4 x 24V in Parallèle ?
Not knowing the configuration, there is still a question to ask:
Are your lithium batteries with built-in BMS compatibles to be put into series ?
No, the order does not matter.
16 People are following this question.
