Hi can I connect somehow the Smart Battery Sense (10M) bluetooth to the Cerbo GX?
The Smart Battery Sense can not be connected to a SmartShunt or BMV712.
But both the SmartShunt and BMV712 can have a temperature sensor connected themselves: https://www.victronenergy.com/accessories/temperature-sensor-for-bmv-702. When the SmartShunt or BMV712 is connected to a Cerbo, the temperature is also available on the Cerbo.
This does use the auxiliary input of the SmartShunt or BMV712, so measuring mid voltage deviation or an auxiliary voltage is then no longer possible.
Kind regards,
Thiemo van Engelen
14 People are following this question.
