aeneby avatar image
aeneby asked
Venus GX not sending data to VRM
My Venus GX has been unable to communicate with the VRM portal for
about a month now, as in no data is uploaded, device list says "Last
seen a month ago", etc. On the GX remote console, "Last contact" always
shows "---" and "No error".
My installation ID is 9884e3b3e091.
- Network is fine, the GX has an IP address, DNS servers, etc. I have run through the steps at https://www.victronenergy.com/live/ccgx:start#trouble_shooting_data_logging.
- I am able to curl ccgxlogging.victronenergy.com from the commandline
on the GX (gives 403 Forbidden but shows that I can reach the server)
- If I disable VRM logging on the GX, tail /var/log/vrmlogger/current,
then re-enable VRM logging, I get the following output:
@400000005edad70d1684946c MainThread-vrmlogger: Starting to log, logmode == LogToVRM, url == http://ccgxlogging.victronenergy.com/log/log.php
@400000005edad70d1c6aa2a4 MainThread-http_endpoint: Internal backlog buffer initialised. Count = 9
@400000005edad70d1d89e5b4 MainThread-http_endpoint: Found '/run/media/sda1' as remembered external path
@400000005edad70d1db03a34 MainThread-http_endpoint: Checking '/run/media/sda1' for suitability for external storage
@400000005edad70d1e93899c MainThread-http_endpoint: Found /run/media/sda1 as external storage dir
@400000005edad70d20618724 MainThread-http_endpoint: Extra SQLite DB made at /run/media/sda1/vrmlogger-backlog.sqlite3
@400000005edad70d20730f6c MainThread-http_endpoint: Made /run/media/sda1/vrmlogger-backlog.sqlite3 the active buffer
@400000005edad70d20eb641c MainThread-http_endpoint: Starting sender thread
@400000005edad70d21eb019c MainThread-http_endpoint: Reading from {0} resulted in an error. Doing nothing.
@400000005edad70d22064de4 MainThread-http_endpoint: Started sender thread
@400000005edad70d2219a704 MainThread-http_endpoint: HttpEndpoint initialised, http worker thread running
@400000005edad71022645c04 HTTPThread-vrmhttp: Using existing VRM auth code
It doesn't seem to progress beyond this point. Am running v2.54. Could there be some problem at the VRM end?
VRMVenus OS
Jaco Reinecke avatar image
Jaco Reinecke answered ·
Seen it once before. the user has lost connection for over a month, rebooted his Venus, and all ran again.
Just a long shot ...
