cedar avatar image
cedar asked
Solar System for 4s 16.4v NMC Lithium Ion Batteries
Hi all,
I am designing a custom solar system setup and want to be sure it will work.
Here's details on all components
Solar Panels - Two 12v panels at 115 W each (already owned)
Charge Controller - Victron BlueSolar MPPT 100/30
  • https://www.amazon.com/Victron-Energy-BlueSolar-Charge-Controller/dp/B076N5PTBN/ref=sr_1_3?dchild=1&keywords=victron+bluesolar+100%2F30&qid=1590864560&sr=8-3
Batteries with BMS - Nissan Leaf Generation 2 Battery Module Lithium Ion NMC
  • https://www.techdirectclub.com/nissan-leaf-generation-2-battery-module-lithium-ion-1-kwh-per-set-66-amp-h-12-volt-configuration-w-option-lot-of-2/
  • 2 units at 500 Wh each = 1000Wh x 70% usable = 700Wh usable. These batteries are 60-70% usable capacity (I guess because BMS limits it?)
  • BMS - https://www.techdirectclub.com/4s-bms-30-amps-assembly-kit-for-2-nissan-leaf-lithium-ion-battery-g1-g2/
Inverter - Victron Phoenix 12V 500W
  • https://www.amazon.com/Victron-Energy-Sinewave-Inverter-VE-Direct/dp/B01N4J9OOM
Wall Charger - 54.6V 9A YALANCHA
  • https://www.amazon.com/Charger-Battery-Aluminum-Electronic-Wheelchair/dp/B07RQS96W5/ref=sr_1_2?dchild=1&keywords=48v%2B9a%2Bcharger&qid=1590814661&sr=8-2&th=1
My goal is to disconnect the solar panels and connect the wall charger (powered by generator) on cloudy days. The reason I chose a 48v charger is because I will eventually get a 48v battery for an electric bike so I'd need it anyway. I calculate that I can plug this charger into the inverter to charge the bike battery from the Nissan Leaf batteries. What do you think my potential issues are? Thanks a ton!
Lithium Batterysolarcharge controller compatibility
wkirby avatar image
wkirby answered ยท
This would probably work, although it's a bit fiddly and you'll likely tire of it in time.
The best way is to use a MultiPlus instead on the Phoenix Inverter, then you can use the MultiPlus to charge the batteries from the generator.
cedar avatar image cedar commented ยท
Hi, can you explain why it would be fiddly and tiresome? The only thing I see is having to plug/unplug from panels/charger, I wouldn't consider that too much of a burden. I looked at the Multiplus but even the smallest is more expensive than the controller, inverter, and 48v charger combined. I wasn't able to see how it could act as a 48v 9a charger as you say but I didn't look too hard so I'll take your word for it.
0 Likes 0 ยท
Battery Compatibility
