macca61 avatar image
macca61 asked
SOC going to 100% immediately
Hi i have a recent install 4 x 200 a/h lithiums, 2 solar banks x 2 controllers the battery SOC gradually creeps down overnight as i would expect but in the morning as soon as the PV are lit up by the sun the SOC goes straight from say 89% to 100%, obviously this not correct , any ideas please
SOC
Hi @Macca61 How are you reading SOC? There is not quiet enough information about your system in your description. But most issues like this are settings related.
Jaco Reinecke avatar image
Jaco Reinecke answered ·
Jip, I had same. I assume you have a BMV?
These are the settings I used for the BMV, adjust as per your lithium banks voltages:
Settings Set:
Bulk : 54.6v
Float : 53.4v
Charge: 70amps
BMV Charge Efficiency: 99%
BMV Peukerts Exponent: 1.05
BMV Charged Voltage (0.3% below Absorption) : 56.7
BMV Tail Current: 2% (~2 to 4%)
BMV Charged Detection Time: 3 (~2 to 5 min.)
Sync voltage to be about 0.2 to 0.4 below absorption voltage.
Configure the tail current parameters so it syncs reliably.
