Inverter/charger config is in VEConfigure.
MPPT Config is in VictronConnect
Please can you help? Is this the correct place to check and alter the Absorption voltage via VEConfigure as shown in the attached pic? If so, should I raise or lower it here?
Victron Connect can't find any VE Direct devices through my MK3 Interface to check the MPPT voltage. I have downloaded the latest driver v2.12.16 but it still won't connect.
Thank you
The MK3 adapter is not able to connect to VEdirect devices.
Please see the Victron Connect Manual here for how to connect various devices to Victron Connect with various computers:
https://www.victronenergy.com/live/victronconnect:start#connecting
https://www.victronenergy.com/live/victronconnect:start#compatible_victron_products
Thank you. Therefore do I need to buy a VE.Direct to USB interface to connect to Victron Connect - to check that the Absorption voltage in the MPPT is slightly above the same setting in Victron Configure 3 inverter/charger to increase the SOC accuracy?
If so, I guess this also means that I need to connect the VE.Direct to USB interface to the back of the Color Control GX usb port. On the Easy Solar this is rather awkward. I suggest it would be much easier if the various ports were accessible from the front, without the need to remove the front panel.
3 People are following this question.
