jond avatar image
jond asked
Venus GX not showing up as WiFi option on my laptop or smartphone
I can't connect to venus GX via wifi. It doesn't show up as an option to connect to. Venus is 30cm away from laptop & phone.
I have tried to put the wifi on and off as per manual:
3.2 Small button located to the right of the green 14-Terminal Connector Block
Short press: WiFi Access point on/off
Long press: reset all network settings to factory defaults
I have also tried Ethernet route and VRM doesn't pickup the venus.
What are my options here? Do I maybe have an defective product?
VRMVenus GX - VGX
carel-landman avatar image
carel-landman answered ·
Hi there!
Just a suggestion, if you have the Victron Connect app, connect to the Venus with an Ethernet cable and check if the connect app picks the Venus up. Alternatively, I would advise you to contact your Victron dealer with regards to a possible faulty product.
