fs67 avatar image
fs67 asked
Phoenix Multiplus Error when disconnecting 220V appliance - Overload, Low Battery and Temp error
On our boat we have a Phoenix Multiplus 12/1200/120 which used to work fine. Currently it goes frequently into an error condition when disconnecting a 220V appliance, with three leds switching on on the control unit:
Overload
low battery
temperature
I tried to diagnose the error as we are on vacation and need the 220 V for our cooking appliance. Initially I assumed it was due to low battery (even though our battery voltage remained stable and the battery monitor indicated 75% load approx.)
Charged our battery pack with the generator, waited for the Phoenix to cool down. Tested the inverter using a small water heater. Current draw 100 Amps at 12 Volts. Ripple measured at the battery peak 300 mv at start of the heater. A pretty constant 260 mv while the water heater was in operation. No errors recorded.
Once the waterheater stopped operating I could hear what sounded like a relay switching a couple of times in the Phoenix Multiplus. The ripple current came down to zero but peaked at about 50 mV and 100 mV while I the Phoenix unit made the switching sound. Subsequently the PHoenix went into the error condition (Overload + low bat + temp).
What surprises me is that the error is generated when the inverter switches off. I had seen it earlier when pulling the plug from an ipad charger for example.
Any advice on what could be the issue?
Thanks,
Frank
Phoenix Inverter
chicchis435 avatar image
chicchis435 answered ·
Didn’t you find the answer the this Frank? I am currently getting the same error lights and the inverter is switching off. Trying to diagnose it but can’t find any reference to what these leds signify
