Does anyone have a copy of the V2.33 file for Colour control?
Hi
Yes you can down load here.
http://updates.victronenergy.com/feeds/venus/release/images/ccgx/
This is old an version why would you use this? the newer version are far better and less bugs etc.
Regards
Rob D
NZ
16 People are following this question.
SMA STPTL-30 + data manager M + Victron Quattro = ESS + zero feed-in
Quattro based SOC % counts down too slowly but CCGX displays correct AC load wattage
Batteries apparently losing charge on light load
GX GSM not logging data into VRM Portal
Can Color GX use Wifi for remote VRM comms and wired LAN for direct comms to SolarEdge HD Wave
