mahdi avatar image
mahdi asked
Smart Solar battery current reading in connect app broken since update
Since updating the Smart Solar firmware from within Victron Connect (Android), the battery current reading is getting stuck on the first reading it takes at start-up.
For instance, if I force the app to sleep, then open it, it will read the amount of current going to the batteries (seems to be a correct reading), and then stick on that number. The other readings update correctly as I increase/decrease the load.
If I then quit the app and then go back into it, the reading shows the correct figure for a second, then goes back to the previous one and stays there.
VictronConnect
mvader (Victron Energy) answered ยท
Hi @mahdi thank your for reporting this - we found the issue and are fixing it. I expect an updated VictronConnect app that fixes this within a few days.
mvader (Victron Energy) avatar image mvader (Victron Energy) โ™ฆโ™ฆ commented ยท
Hi @mahdi, an update: last night we released VictronConnect v5.24, which fixes this issue. In case youโ€™re on a Apple phone/tablet or laptop, it might take max a few extra days for the store to accept the version and make it available for you.
0 Likes 0 ยท
mahdi avatar image mahdi mvader (Victron Energy) โ™ฆโ™ฆ commented ยท
Thank you!
0 Likes 0 ยท
