yachtnomis avatar image
yachtnomis asked
Help me with VE.bus reconfiguration
Hi all
Our victron equipment is connected by a CAN bus as shown in this picture.
BMS (1/2) is faulty and we are waiting for a replacement unit. I believe that the faulty BMS (1/2) is a “dead node” in our network and is causing this error message:
The error message is preventing us from charging through the second BMS (2/2).
As a temporary fix I want to disconnect the faulty BMS and Skylla 1 and 2 which serve it, from the network so we are left with this:
1. Am I correct in believing that the faulty BMS is causing the error message from the Skylla?
2. Can I reconfigure the CAN network as shown in the sketch?
Look forward to your answers.
Best
Sam
ve.bus bms
wkirby avatar image
wkirby answered ·
Yes, it is quite possible it is causing the error message.
Yes, you can connect it like that, you should leave the terminators on the end nodes like they are.
