The Ve.Bus BMS data sheet indicates it has an operating voltage range of 9-70VDC but only 12V, 24V and 48V systems are mentioned. Can you confirm the BMS can be used with 36V system?
Hi, why would you do that? We dont have any 36V inverter/chargers.
If just for the allow to charge and allow to discharge contacts; then yes.
3 People are following this question.
