ray-mont avatar image
ray-mont asked
VictronConnect 5.21(5) problem on iOS 13.3.1
In version VictronConnect 5.21(5) On iOS 13.3.1
Going to the VRM
Then to my Smart mppt controller 100/50
It is not possible to which the charger off for maintenance
On the android app it still work
Am I the only one?
Ray
VictronConnect
ray-mont answered ·
Solved today with
VictronConnect 5.21(beta5) build7
MPPT SolarChargers:
  • Add firmware v1.50:
    • Change fast overvoltage protection threshold back to what it was before v1.47, on all non 250V models, due to possibility of mis-triggering on some systems (normally 12V, small battery and noisy load). The fast overvoltage protection threshold was changed, on v1.47, mainly for the units that have the new PV Short Protection strategy (250V models).
    • Fix charger enable/disable button
BMV:
  • Fix display settings that depends on the auxiliary input doesn't show
  • Fix auxiliary input section values are overlapped
Mark avatar image
Mark answered ·
I reported this back about 2 weeks ago,I’ve tried it on 3 different mppt’s and the Switching off for maintenance function doesn’t work!...also on the bmv 712 you can’t turn on/off the back lit display through the app in ios
