Hello.
My BlueSolar PWM LCD 12/24V-30A has the error code LSC (or L5C).
Cant find anything.... pls help
thx Reto
Hello.
thx Reto
Has this error cleared yet? Have you tried disconnecting the PWM from the whole system and letting it sit for a bit before reconnecting it may help to clear the issue?
Alternatively a firmware update may help.
Hey. Thx for the response. Error still there... i tryed to disconnect for 1 hour... but error comes again...
@Wueeschi I am sorry to hear that. I have only seen one other post here with the same issue. If you have a distributor near you then it may be possible to contact them and find a resolution.
The error is LSC, I assume it means Load Short Circuit.
See page 9, https://www.victronenergy.com.au/upload/documents/Manual-BlueSolar-PWM-Charge-Controller-LCD&USB-12V-24V-5A-10A-20A-EN-NL-FR-DE-ES-SE-IT.pdf.
16 People are following this question.
