strop avatar image
strop asked
Battery Discharge Protection - Inverter
I have a mobile (Caravan) system that is Lithium based but I DO NOT have Victron Lithium batteries. My batteries also do not have an accessible BMS. They are a Renogy 170 AH lithium batteries.
My system is charged via a Victron 100/50 Smart Solar MPPT and a Victron 30 amp AC charger. I also have fitted a BMV712, smart battery sense and a 65 amp Smart Battery Protect.
I am about to install a NON Victron Inverter 2800/5600 watts to see how much I can do via 240v instead of gas. Induction cooking etc.
my question is about how I best protect my batteries from over discharge whilst using the inverter.
I have read that you should not use a Smart Battery Protect on an inverter. Is this correct?
if you can then the 220 amp model it may be a bit small (2640 watts).
Can I use the BMV712 to activate a relay to disconnect the inverter?
Are there any other alternatives?
Thanks
Battery Protectinverter current draw
Matthias Lange - DE answered ยท
The easiest thing would be that you can programing a low voltage cut-off directly at the inverter. Set this to 11V or 11.5V and you should be safe.
OR
If the inverter have a connector for a remote on/off switch (like all Victron inverters) than you can wire this connector to the relay of your BMV-712.
tex260z avatar image tex260z commented ยท
Thanks, that takes care of the inverter, but not the ELV lights, or 12 volt water pump etc.
0 Likes 0 ยท
Matthias Lange - DE avatar image Matthias Lange - DE โ™ฆ tex260z commented ยท
For other DC loads you can use the Battery Protect.
https://www.victronenergy.com/battery_protect
0 Likes 0 ยท
joep avatar image joep commented ยท
@Matthias Lange - DE this may be dangerous for your Li bank, my 12V 3kW Phoenix inverter consumes ~ 400mA when in LVP! So that will quite quickly drain the last bits out of your Li bank. The remote on/off switch seems to be a better solution, although that also seems to consume a little bit of energy.
0 Likes 0 ยท
tex260z answered ยท
Firstly be aware of the maximum amps discharge limitation of any LiFePO4 battery with built in BMS, I got caught out on that. That is a pretty big inverter. I am running an induction cooktop flat out on a 200 Amp LiFePO4 for more than enough time to cook meals.
Secondly if everything is running through your BMS, that will provide low voltage cutout protection. I bought a Victron BP, but ended up not needing it.
I am still waiting for confirmation that my hookup for everything through my 3 port BMS is correct from others, (see my pictures attached to my last question).
aceclement avatar image
aceclement answered ยท
I just recently embarked on the idea of a diy solar battery generator and was having a hard time grasping the battery protect instructions. I finally figured out how to properly set up my battery protect with an inverter that had no remote switch.
I made a video about it to help anyone else having a hard time. https://youtu.be/U10wdEWVctk
tom4x avatar image tom4x commented ยท
"This video isn't available anymore"
0 Likes 0 ยท
Victron BatteryProtect product page
