tonyjogs avatar image
tonyjogs asked
Configure Quattro 48/10000 from VRLA to LiFe Battery
Hi All,
Please help.
Config question on Quattro 48/10000 off grid system:
  1. Battery has just been changed from VRLA AGM to LiFe PowerPlus Energy
  2. Do I need to log into inverter through VEConfig 3 and change from VRLA to Lithium voltage parameters, this considering I have already completed the following config changes via Victron Connect:
  3. System has BlueSolar MPPT 150/85tr with VE.Direct bluetooth dongle (have adjusted config to suit Lithium voltage parameters)
  4. System has BVM - (have adjusted config to suit Lithium voltage parameters
With the above in mind, do we need to change battery config internal to inverter also? If so can this only be achieved with a MK2 or MK3 USB - or are the voltage changes we have made in Victron Connect applied to the inverter automatically?
Any advice greatly appreciated!!
Lithium BatteryVEConfigure 3
Alexandra avatar image
Alexandra answered ·
@tonyjogs
A query on 2. Did you use Victron Connect to change the config through the Mk3 on the multi? Or was Victron connect used for the smart charge controllers only?
You do not need an Mk3 if you are able to use VRM to remote configure the Multi. It is advisable to correctly program the Multi for your batteries. Think of it as a fail safe if other elements in the system stop working correctly.
Battery Compatibility
