greg-1 avatar image
greg-1 asked
HEX Protocol Whitepaper v.10 - Remote control section not clear
I bought Victron MPPT 100/50, BMV 702, Lithium SuperPack 768Wh, and even Victron solar panels. All of it because of the great community support and the ability to read status & control those devices without using manufacturer software.
Unfortunately, VE.Direct HEX Protocol MPPT whitepaper rev. 10 (latest) is promising a feature that does not work: the Remote control registers section (p. 18 and p. 20) states that it is possible to upload battery voltage and temperature to a MPPT (from a BMV). Well, this morning in Darmstadt, Germany my MPPT was happily full-blown bulk-charging the Lithium while the battery temperature was 4deg C. According to Victron SuperPack specs this is below the authorized level. All this in spite of a Python script constantly uploading BMV battery voltage and temperature to the MPPT.
Question (supplication...): can the Remote control registers section in HEX MPPT whitepaper be further clarified regarding the Battery voltage & temperature sense commands, their expected response (currently I'm getting "1"), and whether it is necessary to modify the MPPT Network mode to make them work?
MPPT ControllersVE.DirectTemperature Sensortemperature compensation
MPPT Product Page
MPPT Error codes
VE.Direct protocol FAQ
Victron temperature sensor disambiguation table - which product supports which sensor
