jamesk avatar image
jamesk asked
Error 67 - BMS Connection Lost on Smart Solar 150/100-Tr VE.Can
I have a Smart Solar 150/100-Tr VE.Can connected by VE.Can to a MG Energy Master LV (With 2 x 200Ah HE batteries) and a Color Control GX. There is also a Multiplus 24/3000/70-16 connected by VE.Bus on the same system.
I'm having an occasional 'Error 67 - BMS connection lost' from the Smart Solar but I have unfortunately been unable to pinpoint what exactly is causing the issue. It never happens when the solar is isolated but randomly when solar is generating. It does not automatically recover unless I clear the issue by isolating our solar panels and reconnecting. Is this a known issue with Smart Solar VE.Can variants? Details are below. Many thanks!
Details:
DVCC Enabled
Smart Solar 150/100-Tr VE.Can Firmware v̶1̶.̶0̶3̶ v1.04
MG Energy Master LV Firmware v1.22
Multiplus 24/3000/70-16 (230VAC) Firmware v469
Color Control GX Firmware v2.51
BMSsmart solar set-up helpVE.Can
Hi @JamesK
Is the system online on VRM? if so, can you post the VRM id?
jamesk avatar image
jamesk answered ·
@Daniël Boekel (Victron Energy Staff)
Is there a way I can send the VRM ID to you privately; I don't want it to be shared publicly.
Many thanks!
Yes you can select 'viewable by moderators'
Hi @JamesK
As you can see in the graphs, the BMS is indeed not visible when this error happens, when the BMS is disconnected, MPPT's etc. are supposed to stop charging.
So next step is to find out why the BMS disconnects, the first place to look for: wiring, check / replace comms cables to see if that makes a difference.
Also I would advice to update the inverter firmware.
jamesk avatar image jamesk commented ·
Hi @Daniël Boekel (Victron Energy Staff),
Many thanks for your help - we have tested with different RJ45 cables and the problem still exists when running on VE.Can. We have noticed that when we switched to VE.Direct, the issue doesn't arise. We have also tested the MPPT with another system with firmware version 469 to no success.
Daniël Boekel (Victron Energy Staff) avatar image Daniël Boekel (Victron Energy Staff) ♦♦ jamesk commented ·
Hi @JamesK
how / where did you terminate the CANbus?
jamesk avatar image jamesk Daniël Boekel (Victron Energy Staff) ♦♦ commented ·
I have a VE.Can terminator on the spare port of the Smart Solar and one on the CCGX. I then daisy chain RJ45 from Smart Solar to Master LV (Aux. Can side) to CCGX.
Many thanks for your assitance,
James
Hi @JamesK
We're working on a solution for this, a bug was found, hopefully we have a fix soon.
froste9 avatar image froste9 commented ·
has this bug been fixed, i just had this same thing happen this morning.
justin-selleck avatar image
justin-selleck answered ·
I am having the same issue. A BMS is attached to the BMS Can side on a cerbo GX.
Product
Generic Can-bus BMS battery (batrium)
Firmware version v4.7
Last connection 10 minutes ago
Product
SmartSolar MPPT VE.Can 150/100 rev2
Firmware version v3.05
Last connection 8 minutes ago
Serial number
VRM instance 1
Product
Cerbo GX
Firmware version v2.66
Remote on LAN
Firmware updates Automatically checks for updates to official release
Last connection 7 minutes ago
Logging interval 15 minutes
Last power up or restart 2021-06-10 13:17
When I remove PV power the error goes away. When adding back it shows a quick charge ~1600w then goes to float. After several minutes it then goes back to the error 67 state.
have you found a solution to your problem? i'm having the same issue and i also have a batrium bms
Martin Coetzee avatar image
Martin Coetzee answered ·
i am also having the same on 2 sites. checked everything. looses connection for a few seconds then fine again.
Paul avatar image
Paul answered ·
Same issue here with MP2 5000/48, Smartsolar 250/100 and a "dumn" LiFePO4 51V battery with it's own stubbern (and regretfully paid support including) Babatrium BMS.
Every now and then, I see this message with a beep and after resetting the beeper and waiting some time, the error message disappears.
Since I am thinking about upgrading ith two MP5000/48's and two SmartSolar 250/100's, in combination with the ESS assistant for feeding in the abundant PV power, I am not sure if going the DC to AC way is the best choice here.
Might go for the Victron as a smart battery and leave the power crunching by a Fronius 8.2 on the inverting output of the Victron.
One might lose some efficiëncy bat overall, if the Victron fails, the Fronius will still generate power and feed it back to the grid, allbeit without backup facility.
Question here: can somebody of the Victrn staff help me out here?
I am going to pull the plunge quit soon.
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
