Hi. I have one victron orion-tr 12/12 30a in my van and I'd like to install another to give me 60amps,total charging. Can anyone advice my how I'd need to wire the 2 units many thanks
@Moonhead911, may I presume that you're referring to the Orion-Tr Smart rather than the Orion-Tr?
...with such a similar naming convention for a very different product, it's important to be very careful of getting the name right both when ordering as well as when making technical support inquiries!
You should wire the two units exactly as you would any other charge source: POS and NEG from the start battery (POS fused, of course), POS and NEG to the aux battery (again, POS fused, of course).
If you're not connecting straight to the battery(s) then you may of course connect to POS and NEG busbars, so long as you use appropriate cable gauges and fuses for all connections. The Orion-Tr Smart will accept 6AWG (16mm2) wire at both its input as well as its output terminals. For appropriate wiring connections in general, in various configurations, I recommend that you download and thoroughly read and understand the free Wiring Unlimited book that Victron has made available.
@Moonhead911 We have installed the Orion Smart 12 30/30 in pairs several times. We do install a "hot wire" from the ignition and manually turn both units on. Doing this is simple. If you cant do this, then tuning the voltage based engine running "sense" is challenging as the voltage drops when one is starting up just a fraction before the other and lockout on the second unit may occur. Having exactly the same cable length and size from the alternator is essential. The load side is less important perhaps.
Bruce
@safiery can you please provide some details on how to use the "hotwire" ignition option? The manual is pretty confusing on this point, do I remove the bridge and which port exactly do I attach the live ignition wire? I do not want to use the auto voltage sense feature but rather have the unit come on and off with the ignition. Thank you !
Yes the new smart DC to DC charger. I all ready have one unit wired up and installed. I just wanted some information on wiring them in parallel
I would also like information about wiring them in parallel. It would seem that this information isn’t available on the Internet.
It's in @Justin Cook - Bay Marine Supply USA reply above. Make sure cables are sized for the current.
Orion-Tr Smart Dc to DC Charger, Alternator Victron Energy
__________
Orion-Tr Smart DC-DC Charger Isolated 12 / 24 Volt- Product Page
Orion-Tr Smart DC-DC Charger Isolated 12 /24 Volt - Datasheet
Orion-Tr Smart DC-DC Charger Isolated 12 /24 Volt - Online Manual
__________
Orion-Tr Smart DC-DC Charger Non-Isolated 12 /24 Volt- Product Page
Orion-Tr Smart DC-DC Charger Non-Isolated 12 /24 Volt- Datasheet
__________
19 People are following this question.
