How to use the phoenix inverter to protect your battery to not being fully discharge?
thanks
thanks
if you have VE.direct version you can set the values very easy. Install VictronConnect app and you can play with all settings in demo mode. Settings you are seeking for are Dynamic Cut off, Low Battery shut down, Low Battery restart ... https://www.victronenergy.com/live/victronconnect:start
3 People are following this question.
