usatractor avatar image
usatractor asked
EVE LFP Batteries
Has anyone had any experience integrating EVE lithium batteries with Victron inverters?
Thank you
MPPT ControllersLithium BatteryCCGX Color Controlvictron
kai avatar image
kai answered ·
Not specifically. But if its raw cells, then ideally you need to think about a BMS, cut out relays, and the surrounding interface circuits.
As far as the Victron inverters are concerned, a battery bank is a battery bank.
pau1phi11ips avatar image
pau1phi11ips answered ·
It's an old thread but I'm using Lichen 280Ah cells (which are basically the same thing as the EVE cells) with a Multiplus II 24V 3000VA inverter. Did you end up using them?
llubi avatar image
llubi answered ·
I’m using them in 2 camper vans. No problem at all, not using any BMS, just checking cell balance and no problems for about 14 months or so
