justinschrock avatar image
justinschrock asked
Is it possible to have 2 AC input and 2 outputs on MultiPlus?
I have a MultiPlus 3k inverter that replaced an old xantrex inverter when I upgraded to a lithium battery bank. The Xantrex was a 2 in 2 out and the victron is a 1 in 2 out. How am I supposed to hook up the other leg so my new inverter stops overheating and dropping power to 1/4 of my rv? Why did victron make this a 1 in 2 out? Is there a way to expand/add a component inside to facilitate my other line in? Is there an actual troubleshooting guide anywhere?
MultiPlus Quattro Inverter ChargerAutotransformerPeak Power Pack
ben avatar image
ben answered ·
How did you hook up both legs to your Xantrex in your prior setup? Which model was it?
I'm not aware of any inverters that can accept two different waveforms, like L1 and L2 on a 240V/50A USA RV split phase power pedestal, at the same time.
Also, how did you determine "1/4" of your RV is losing power? What does that mean exactly?
The reason you are having an issue is almost certainly due to something else.
