Is there a way to clear warnings and errors from a Color Control? Can be cleared via VRM???
Thanks
Thanks
Hi, the notification list on a ccgx is emptied out by rebooting it. And by going to an alarm and clicking it, you acknowledge it which stops the beeping.
If you’re talking about alarms on VRM; its different.
Hi, I have an alarm on the VRM that I cannot clear, although it has been resolved on the site. How do I clear the "Active" alarm? Thanks
@Ant I have seen this behavior too. It was the low voltage alarm in my case. The only thing that helped was, to delete the alarm in VRM settings, and set it up new.
I think, it was triggered from a deleted Multi. After a firmware update of the MK3, it was shown twice in device list. But I am not sure.
Regards,
Markus
You know which are the keystrokes to reboot the ccgx without turning it off?
Recommended to use Markus's method via software.
You can also press the two top 'menu' buttons simultaneously to reboot it.
7 People are following this question.
