jtroybailey avatar image
jtroybailey asked
Update Failing on Raspberry Pi 4
Hi All,
I recently setup a Raspberry Pi 4 using the image from (https://community.victronenergy.com/questions/25666/venus-on-raspberry-pi-4.html?childToView=38071#answer-38071 )
All is working well, and it is reporting to VRM no issues, so I know it has internet, however when checking for updates I receive the below message.
Any Ideas? Thanks.
firmware updateRaspberry Pi
jeroen avatar image
jeroen answered ·
This is normal, the official updates only work once the raspberrypi 4 is supported. For now there are only images.
jtroybailey avatar image jtroybailey commented ·
Thanks, understood. Will it start to update automatically, or will i need to re-image it to start getting updates?
Also, i am surprised it uses different packages to a Pi2, i assumed sames packages, just different image for the Pi4 hardware.
Thanks Again.
jeroen avatar image jeroen ♦ jtroybailey commented ·
Not sure if it becomes updatable, status quo it will become updatable. But since it is not supported yet, I would like to preserve the freedom to make breaking changes. Most packages should be roughly the same. Which packages are different?
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
